This is a BLE sensor. It is quite easy to get measurement results and use in home automation with NODE RED or any MQTT based system.
Wireless sensor for monitoring home plants.
plant_sensor_bottom.stlBottom case part, print 0.5mm nozzle with 0.6mm external perimeter, 100% infill.Standard Tesselated Geometry - 41.49 kB - 04/15/2019 at 19:32 |
plant_sensor_top.stlTop case part, print 0.5mm nozzle with 0.6mm external perimeter, 100% infill.Standard Tesselated Geometry - 39.14 kB - 04/15/2019 at 19:32 |
A simple application for iOS / Android is ready. Supports multiple sensors.
