So far so good with the debugging. I’ve verified that the board can drive Neopixel dotstars, RGB, RGBW leds and motors. I also verified that the SD can be used in MicroPython.
A project log for ESP32 LED & Motor Driver
An ESP32 based controller that can drive any kind of LED strip, or motor. Includes microSD, USB-UART, and large voltage range input.
