Full hardware mock-up is now operational (yes, it is damn ugly).
The current mock-up version is based upon:
(1) Arduino MEGA 2560
(2) Arduino MEGA SRAM shield (my PCB is modified for 56k RAM instead of 32 in the original version) https://hackaday.io/project/21561-arduino-mega-2560-32kb-ram-shield
(3) Arduino SD card reader; this version is for Uno, but runs on Mega with pins 10-13 using Soft SPI (library mods by David Mellis). Note that the standard SD library will not work if the classic Uno shield is transplanted to MEGA:
https://github.com/ptravnik/Retro_CALC/tree/master/SD2
(4) Piezo speaker on line 9
(5) Hardware keyboard on lines A0-A4. The driver is here (check the Morse code example!):
https://github.com/ptravnik/Retro_CALC/tree/master/HWKbd
(6) LCD screen 128x64 pixels on SPI. The driver is U8g2 from Oli Kraus (it writes Cyrillic and other character sets):
https://github.com/ptravnik/Retro_CALC/tree/master/U8g2
https://github.com/ptravnik/Retro_CALC/tree/master/HWKbd/KiCAD
All hardware has been tested and fully operational. Now the next step: LCD terminal and RPN calculator part.
ptrav
