3D printed hooks/grips for glasses
My new glasses kept sliding down my nose and falling off. Simple hooks like these made my life a lot easier.
Here's a video version if that's your preferred method:
I've designed three versions based on what I found online.
Hook
Has a very strong grip, it's impossible for your glasses to fall down with this. That's also it's downside; it's tricky to put them on and even harder to take them off. Because they're so thick, your ears might hurt after a while, as did mine.
Small hook
This one hopefully  addresses the cons of the larger hook; it's smaller, so it shouldn't rub against your skin, yet it still retains the hook for a strong grip.
Ring
The ring is the best choice for daily wear. It won't help if you're doing some sort of sports, but apart from that, it performs excellent and it's the one I'd recommend to most people. It's what I'm using 99% of the time.
Blank versions
It's impossible to design a hole that will accommodate all the countless shapes and sizes of glasses out there. That's why I'm including a blank version of each design as well; simply import the blank into Tinkercad and cut out a hole that will fit your glasses.
ring.stl
Standard Tesselated Geometry - 1.58 MB - 04/03/2019 at 15:59
Download
hook.stl
Standard Tesselated Geometry - 7.11 MB - 04/03/2019 at 16:01
Download
small hook.stl
Standard Tesselated Geometry - 6.16 MB - 04/03/2019 at 16:01
Download
blank_ring.stl
Standard Tesselated Geometry - 1.76 MB - 04/03/2019 at 15:59
Download
blank_hook.stl
Standard Tesselated Geometry - 7.08 MB - 04/03/2019 at 16:02
Download
View all 6 files
  • 1
    Print settings
    You should use some sort of flexible material, like TPU or Polypropylene (PP). Hard plastic will otherwise rub against your skin, not a comfortable feeling by any stretch.
    Flexible filament is notoriously hard to use, make sure to:
    • print very slowly, somewhere between 15 and 20mm/s,
    • disable all retractions completely and
    • turn off the heated bed or only use sub 30'C temperatures.
View all instructions
