Hackaday.io Hackaday.io
Sign up Log in
DIY Nonlinear Circuits Vactroll PiLL build
Building this eurorack module from the PCB
cementimentalCementimental
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
409 followers
  • Description
  • Details
  • Files 2
    • View all
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
620
0
409
0
Team (1)
  • cementimentalCementimental
Join this project's team
ongoing project
eurorack NLC 4069 synth diy Harsh Noise
This project was created on 04/03/2019 and last updated 2 years ago.
Description
weird vactrol-controlled phase-locked-loop module. I bought the PCB from NLC. as suggested on the MW thread I tried using a flickering LED and a cycling RGB colour-changing one instead of the normal red. The RGB one I don't think has a dramatic enough effect for my liking but the flickering LED does nice semi-random sequences/arpeggios. so i think i'll make it switchable between red + flickering. I used a DIY vactrol, LDR glued to a square red LED and covered with electrical tape. Sounds pretty great/crazy so far., all sorts of drones and lasers and bees. Need to make a faceplate next.
as someone on the forum suggests it might be a good idea to add a knob to inject a DC offset, gonna try that
info on the circuit:
https://www.muffwiggler.com/forum/viewtopic.php?p=1819732
Files
JPEG Image - 1.52 MB - 06/07/2019 at 20:19
Preview
JPEG Image - 1.56 MB - 06/07/2019 at 20:19
Preview
Project Logs
Collapse
  • panel
    Cementimental • 06/07/2019 at 20:23 • 0 comments
    Made a panel. Drilled a bit wonky but it fits.
View project log
Log In/Sign up to comment
Sign up with Github
OR
Conway s Game of Life on a LED Cube with 16x16 LED on each side
Project Owner Contributor
christianChristian
A studio ghibli inspired simple add on - offering you candy
Soot Sprite Simple Add-On SAO
davedarkodavedarko
I want to build a modular LED panel module using PCB-based LED matrices to display patterns and effects.
Modular LED Triangle Wall Panel
tanguyTanguy
A sparkling LED module for PCB origami. Create some shining constructions with your soldering iron and hand-soldered LEDO!
LEDO
ndgaragendGarage
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "DIY Nonlinear Circuits Vactroll PiLL build", please tell us the reason.
Send message
Remove Member
