Today was busy and productive! I printed out a new Grace model SmallKat and made an assembly instructions document. Check it out here:
In it you will learn how to assemble a smallkat robot, as well as calibrate all its links.
I also added the purchasing direct links on all of out BOM:
https://hackaday.io/project/164727/components
This should fill in the mystery steps in our previous documentation.
Kevin Harrington
