My board design had a LOT of problems.
Let's take inventory of my mistakes, so you can hold them against me:
- The address connections A16 and A17 from the VRAM to the uPD7220 were not set up completely right, causing a strange monitor flicker in mixed mode, and lack of memory access if the software didn't have a special setup
- VRAM control lines were not generated correctly
- The VRAM was not fast enough to do what I had in mind. I thought I checked this and I knew the timing was close, so I must have done my math wrong.
- Probably something else I forgot
I thought there might be a minor issue or two with the design, as the design of the VRAM access is very ambitious - accessing two words per cycle using careful timing, then switching what device controls the memory every other cycle. Yes, a lot can go wrong. But what I didn't expect, is that so much would go wrong. I practically have to re-design more than half the board. Well, that is more or less what I've been working on.
Here's a video showing what the debugging was like; hopefully the video isn't too chaotic:
At some point I realized that I couldn't figure this all out by messing with the hardware directly - there were just too many things wrong with the board. The breadboard was losing me both signal integrity and voltage - the board ran at less than 4.3v. I needed a simulator. Well, I wrote one. It works decently well, loads my schematics straight from KiCad, can show me the VGA video output, and has a few other random features. Here's the source on my personal gitlab server, and here is a picture of it:
