It's a kind of magic...
A project log for MPRT - Modified planetary robotics transmission
The reduction of strain-wave, but using a 'single' stage planetary gearset.
masterofnullMasterOfNull • 04/06/2019 at 18:19•0 Comments
I'm beginning to deduce some of the magic required here to make the gears mesh.
I stumbled upon a compatible gear set by accident originally, but now I think I understand what is actually going on.
The rules:
So basically... for 3 planets I will need multiples of 6 for both the sun and ring gear tooth count.
For the test I've settled on 18 sun teeth, 60 ring teeth, and 57 output teeth.
Planet tooth count is a always a function of the sun/ring tooth count and ends up being = (<ring_tooth_count> - <sun_tooth_count>)/2.  So for this test, they will have 21 teeth.
I increased my pitch a little so it still fits on a Nema 23, from 0.965 to 1.05 and I'm using a pressure angle of 24.
This is what that looks like.
Sliced.
Printing.
