I changed my mind and made the output ring gear something you can actually use right now by adding a bearing.
It breaks the laser cut equal height paradigm, but that could easily be undone by splitting it into three layers.
These three layers are all solid with your output anyway, and so could be modeled to be directly be part of your 'arm'.
Printing...
MasterOfNull
