In my last log I mentioned just a few quick things. Now it's time to tell you the following:
My v0.2 boards are fully functional without any modification. Can't remember when this happened the last time, if ever :)
A few notes:
- current consumption when active in the single digit mA range
- current consumption when OFF: 0.45µA
- wake-up from OFF-mode only by pushing a button connected to the board
- pushing reset == OFF
I wrote a quick first-try program for the boards which I will refine a bit next week and upload.
When this is done, you could order those boards, solder them and add them between your valuable rechargeable batteries and your devices.
I'll put up all the needed files shortly!
Woohoo! How's the ADC going across the VBat range?
Now the fun begins: optimisation!
