Ethernet is Working & a Nice Enclosure
A project log for FBus: Open FPGA Realtime Bus
Defining and implementing a bus protocol that is built around low-cost FPGAs to enable modular and affordable control and DAQ systems.
flowflow 05/02/2019 at 22:320 Comments
I finally managed to get the ethernet chip running i suspect that the crystal had a bad contact. From there on I managed with the help of the pubsubclient library to get the thing talking. Also I managed to score a really nice enclosure for the project on ebay.
I decided to use MQTT for the configuration of the system because it is so leightweight, easy to implement, and well established.
Rich text editor
