I just put together the first usefull Board that can go into the FBus. It has a SAM3X8 and Arduino-Compatible footprints for shields, so now you can hook up any shields to the FBus. Now I will start working on the ethernet interface. I hope that it soon will be possible to upload the bitstreams and firmware images via ethernet.
flow
