I decided to use MQTT for the configuration of the system because it is so leightweight, easy to implement, and well established.
A project log for FBus: Open FPGA Realtime Bus
Defining and implementing a bus protocol that is built around low-cost FPGAs to enable modular and affordable control and DAQ systems.
