2019-03-28 Started testing, numbering and grouping motors by leg.
Evaluating how everything will be connected inside the bodyI kind of like the rubber band colors on the motors. Maybe I'll try introducing a bit of color in the final designWith a small work surface I have to tidy up pretty often. I wonder if I'll have enough room for the robot to stand.
