Little updated board ... v3b
12/19/2020 at 23:05 • 0 comments19V power supply
50V power supply
New v3b boards received
05/21/2019 at 21:30 • 1 commentLittle redesigned
Submitted in PCBway "I CAN SOLDER" competition
05/15/2019 at 07:44 • 0 commentsHere is, order, share, vote, enjoy ;)
New V4 board received
05/14/2019 at 21:19 • 5 commentsThanks to PCBway I received new board, I am excited to test it.
received some power transitors
04/25/2019 at 22:30 • 0 commentsAnd winner is BUL45D2G ;) 3-4mm sparks with single coil ... I try order more from BUL family ...
Big gift from PCBWay - 180$ = FREE board for v4
04/25/2019 at 07:08 • 0 commentsIt is very hard to manufacture this big coil, It is challenge for all pcb manufacturers.
There is lot of very thin and close tracks on big space.
PCBWay took on the risk of production for this boards and accepted this challenge,
and manufacture this boards for my FREE. -
Some long sparks
04/24/2019 at 20:18 • 0 commentsI try before stacking two boards but without success, now with this new power transistor
I am near to killing sparks :) Also I have ordered some new HF transistors -
Some 1-2 mm sparks with 2N3055 transistor
04/18/2019 at 21:34 • 0 commentsThis transistor is no specially selected, just only one on my desk in TO3 package
- 25V
- red LED
- I can make sparks with tube, no spontaneous sparks alone
Experimenting with FZT851 transistor
04/18/2019 at 20:54 • 0 commentsAt first I burn almost all transistor after power on, then I test lower voltage than 36V like for previously tested BD243.
FZT851 at 12V without LED:
- no heating
- 0.2W consumption
- 0,017A
- tube glow 1-2cm above board
- no visible sparks
- when you touch board, current go transistor deathly values
FZT851 at 12V with red LED:
- no heating
- 0.2W consumption
- 0,2A
- tube glow 3cm above board,
- visible sparks if I scratch with tube wires over board
RESULT:
Subjective I think, I have almost same results with FZT851 at 12V like BD243 at 36V
FZT851 is SMD in SOT223 package, is more sensitive and is harder for cooling.
You can see some neon glow on 5-6V.
Schematic
04/13/2019 at 07:42 • 0 commentsI Have plan test new transistor in next week
