Took a lot of soldering buy all 7 motor connectors are now being soldered and connected to the motherboard.
![](https://cdn.hackaday.io/images/651541546356220492.jpg)
The connector at the right bottom is intended to provide 5V and 12V to the Thor robot to power additional electronics and power the cooling fans.
On the left bottom I also provided a spare opening for a DB9 serial cable for additional communication for sensors inside the robot.
![](https://cdn.hackaday.io/images/5395511546356236024.jpg)
Life gets easier for testing every motor independently during software development but also when it becomes part of the robot.
The only missing part is the Nextion display that I reordered after damaging it with a reverse polarity.
