Testing for faster speed.
I am using a timer interval to trigger the motor motion.
By having a loop of "NOP" I managed to get a predictable step pulse of 2.24 - 2.32µS
void MotorExecutionBlock::StepDelay() {
// Code blow should be about 2 µS on a 84 Mhz Arduino Due
for (auto i = 0; i < 40; ++i) {
asm("nop \n");
void MotorExecutionBlock::SendMotorStepCommand(byte step_command) {
REG_PIOC_SODR = PIO_PC3; // X_AXIS_STEP set to high
REG_PIOB_SODR = PIO_PB26; // Y_AXIS_STEP set to high
REG_PIOD_SODR = PIO_PD0; // Z_AXIS_STEP set to high
REG_PIOC_SODR = PIO_PC16; // E0_AXIS_STEP set to high
REG_PIOC_SODR = PIO_PC19; // E1_AXIS_STEP set to high
REG_PIOA_SODR = PIO_PA19; // E2_AXIS_STEP set to high
REG_PIOC_SODR = PIO_PC7; // E3_AXIS_STEP set to high
// Delay 2 micro seconds
StepDelay();
REG_PIOC_CODR = PIO_PC3; // X_AXIS_STEP set to Low
REG_PIOB_CODR = PIO_PB26; // Y_AXIS_STEP set to Low
REG_PIOD_CODR = PIO_PD0; // Z_AXIS_STEP set to low
REG_PIOC_CODR = PIO_PC16; // E0_AXIS_STEP set to low
REG_PIOC_CODR = PIO_PC19; // E1_AXIS_STEP set to low
REG_PIOA_CODR = PIO_PA19; // E2_AXIS_STEP set to low
REG_PIOC_CODR = PIO_PC7; // E3_AXIS_STEP set to low
Which gives these fine tuned motor controlI now speed up the clock pulses (driven by an interrupt) and get a speed of 32 Khz
The bonus is that I have at this speed only used 7.6% of the CPU processing cycles,, I still have 92.4% of available time to do something useful with the processor.
Controlling 7 stepper motors at 32 Khz and have 92% CPU processing power to spare. Think we are on to something. :-)
I also have been running at this speed for 5 minutes and no smoke to see.
