Started to print the Thor upper part I have found created by Sepio: https://hackaday.io/project/26341-building-and-improving-the-thor-robot-arm/log/70087-day-18-redesign-of-art3-and-art4
I needed to reprint the part because I need cooling, and it is a great way to test NGEN how it performs with bigger objects.
I like Sepio's upper part, it looks easier to assemble and has a fan included to cool the upper part.
![](https://cdn.hackaday.io/images/6298441512951936536.jpg)
The Art 3 lower body. 0.3 mm layer heights, Simplify3D estimated this a 7H job but it turned out to be 8H45. You can see the support structures that actually came off very easily.
![](https://cdn.hackaday.io/images/1028711512952047068.jpg)
Inner part of Art 3 lower body.
The day before I tested 3 different materials I received on Friday.
I started with the part that guaranteed failed every single time I used ABS.
- Black = ColorFabb_HT (€ 45/700 gr,)
- Red = ColorFabb_XT (€ 40/700 gr)
- White = ColroFabb NGEN (€ 35/700 gr)
All 3 jobs are 2 hours printing.
![](https://cdn.hackaday.io/images/7820641512952069394.jpg)
Top parts
![](https://cdn.hackaday.io/images/3516871512952093629.jpg)
Bottom parts
That test concluded me to go for NGEN when I print parts for Thor.
Are you going to build 3 robot arms ;-)
One is enough, this was just a test.
I just uploaded the latest version of the arm. Look at build log 20.
