My printer is not big enough to print all parts of the Thor project but dannyvandenheuvel has an interesting variation where 2 parts can be glued together. This is the first part I am trying to print. ART2BODYA_1.stl.
See his project here
https://hackaday.io/project/16665-thor-robot-with-addons-and-gui
This part is expected to be an 5h30 job using ABS.
Update: 3 hours into the print the support structures came lose from the bed
I tried to clean the heat-bed and tried again but the support structures again came lose from the bed at 3 hours into the print.
I believe that the moment I start to print a solid layer on top of these support structures, it pulls the support structures up.
This time I continued the print, and the print ended up being usable.
