Some setbacks no functional Thor robot this year.
My big ball bearing 16014zz 70mm x 110mm x 13mm was canceled by Amazon as undeliverable.
Also my Pololu DRV8825 Driver Carrie did not arrive yet som I have nothing to test my stepper motors.
I have a week of holidays coming up so I ordered 3 Pololu DRV8825 Driver Carries from a different source that I know that will receive in my free time.
My holiday plan is to try to create the control software that will control the motors. And the primary focus will be a reliable 7 motors movement at the same time. I want a fast and fluid moving robots!
Next stage, built restrictions in the software that takes into account acceleration, stepper and speed limits. The last thing you want is a self destructing Ninja robot. Or a robot that kills the payload due to acceleration.
Final stage would be make that code flexible enough to be used by controllers.
