It may be of interest for some people that want to control the Ultratronics v1.0 Pro board but these defines are the constants that are needed for the stepper motor controls.
It took some time to verify them with a real stepper motor.
#ifndef _ULTRATRONICS_H_
#define _ULTRATRONICS_H_
#define X_AXIS_DIRECTION 34 // D34 X axis direction --> PC2
#define X_AXIS_STEP 35 // D35 X axis step --> PC3
#define X_AXIS_ENABLE 37 // D37 X axis enable --> PC5
//BasicStepperDriver stepperX(MOTOR_STEPS, 34, 35, 37); // X-axis
#define Y_AXIS_DIRECTION 23 // D23 Y axis direct --> PA14
#define Y_AXIS_STEP 22 // D22 Y axis step
#define Y_AXIS_ENABLE 33 // D33 Y axis enable
//BasicStepperDriver stepperY(MOTOR_STEPS, 23, 22, 33); // Z-axis
#define Z_AXIS_DIRECTION 26 //D26 Z axis direction
#define Z_AXIS_STEP 25 //D25 Z axis step
#define Z_AXIS_ENABLE 24 //D24 Z axis enable */
//BasicStepperDriver stepperZ(MOTOR_STEPS, 26, 25, 24); // Z-axis
#define E0_AXIS_DIRECTION 46 //D46 E0 axis direction
#define E0_AXIS_STEP 47 //D47 E0 axis step
#define E0_AXIS_ENABLE 48 //D48 E0 axis enable */
//BasicStepperDriver stepperE0(MOTOR_STEPS, 46, 47, 48); // Z-axis
#define E1_AXIS_DIRECTION 36 //D36 E1 axis direction
#define E1_AXIS_STEP 44 //D44 E1 axis step
#define E1_AXIS_ENABLE 45 //D45 E1 axis enable */
//BasicStepperDriver stepperE1(MOTOR_STEPS, 36, 44, 45); // Z-axis
#define E2_AXIS_DIRECTION 41 //D41 E2 axis direction
#define E2_AXIS_STEP 42 //D42 E2 axis step
#define E2_AXIS_ENABLE 43 //D43 E2 axis enable */
//BasicStepperDriver stepperE2(MOTOR_STEPS, 41, 42, 43); // Z-axis
#define E3_AXIS_DIRECTION 38 //D38 E3 axis direction
#define E3_AXIS_STEP 39 //D39 E3 axis step
#define E3_AXIS_ENABLE 40 //D40 E3 axis enable */
//BasicStepperDriver stepperE3(MOTOR_STEPS, 38, 39, 40); // Z-axis
//BasicStepperDriver stepper(MOTOR_STEPS, DIR, STEP, ENBL);
#endif
Disclaimer: Be careful when you use it in your projects, I may have made a mistake.
