I developed the buttons in Inkscape to be used for my Thor project.
I am still in my "Learning Inkscape" phase, it is a big learning curve to become a button graphics designer :-) But basically the button consists of 3 parts. The back color, the text and the reflection.
![](https://cdn.hackaday.io/images/8230591501362642440.jpg)
The button background is a flat solid color. This and the reflection is a gray gradient that uses transparency. This way it makes it very easy do duplicate the buttons and change the color or the enabled/disabled state.
We create 2 different background in Inkscape, one with all buttons disabled and one where all buttons are enabled.
![](https://cdn.hackaday.io/images/6661181501363075461.jpg)
In the Nextion editor load the 2 different backgrounds.
![](https://cdn.hackaday.io/images/9761681501362468606.jpg)
Now we add the buttons on top of the background. To make them transparent,we select the button, go to properties and select "crop image"
![](https://cdn.hackaday.io/images/7729531501362476875.jpg)
We get now 2 items that select the pressed and the unpressed button state. picc0 is the depressed button image data source, picc1 is the pressed button image data source.
![](https://cdn.hackaday.io/images/9296551501362484513.jpg)
The debug view now show that we can individually select a working on./off state of thee buttons.
This way we can get more complex graphical elements that may not be square at all.
