ESPboy.pro v2.1 improvements.
The PRO version is rather complicated and i think it will be sutable only for hardcore geeks :)
For regular users it's better to take EDU version!
1. 2 side buttons added for more comfortable horizontal usage
2. Micro SD card slot added
3. GROVE sensors jack added
4. Some tracings improvement
it's clean side ) Wemos esp8266 is on the another side. on this side should be a battery and if somebody needs SD card reader, it's possible to solder it and then battery will be above. so SD slot just add about 1mm thickness overall
Are you sure with removing SD card over pin header?
