Scan the radio band in the defined limits 300-348 MHz, 387-464 MHz and 779-928 MHz, as long as the CC1101 chip allows. Select the desired frequency and pitch. Easily determine the frequency of active radio signals around you.
Source code https://github.com/ESPboy-edu/ESPboy_Sub1GhzScanner
