Currently this project is built and I used ngrok to connect to IoT without using port forwarding. I am working on figuring how much weight the composter can hold and still turn automatically and will update others one I know. I also want to add a weight sensor
Jamie
You could use current sensor to measure the load of the motor to calculate the weight on the drum
this will be on trial and error method, but cheapest method
