Decided to "pimp" it up for some arbitrary reason. It turns out it's never the way you want it to be, so I hope this is the last one.
What's new:
- New knob, LED light is now inside of the "select" button so it makes a pretty glow.
- Top plate is now fixed by only one screw in the middle, so that the knob hides it.
- Small adjustments to the bottom plate
