Soviet Nixie Clock
Nixie clock with Android support, Web interface support, FM radio, clock/date, sensors, relays, web stream radio stations, bt/wifi control
This is project for all , who want to build special Nixie clock with lot of features.
Main system and hardware features are:
Android app support;
Web interface under HTML5 / CSS / Javascript / jQuery;
Touch display;
MP3 player;
Web stream radio stations;
FM radio with RDS;
Alarm;
Clock / Date;
Sensors for temperature / humidity / barometric;
Relay time control;
RGB backlight of nixies and bottom of clock;
ESP32 with cooperate of Arduino 2560 ;
Bluetooth / Wifi control;
Different languages support;
IRDA teaching control for any infrared controller (TV,Video,Satelite etc...);
Full STL / GCODE support for printers and CNC machining;
(uploaded images are pre-version build - I made clock in last time, but just now I want to totally improve and make the best nixie clock of the world ;-) )
The final video of Nixie Soviet Clock
  • Final video of the Soviet Nixie Clock
    loszelos05/04/2020 at 20:38 0 comments
  • Few next days up!
    loszelos06/21/2019 at 05:30 0 comments
    I'm toooooo sorry, for this very late log. I was on surgery, therefore I was long off. Just now, I had to prepare for exams at my school. I was too busy, but however, I wanted to write this short topic. Just now, I'm almost done with my CNC mill for PCB and small components machine, here this are potos and link for do it :-)
    To All: Please be patiently. Just now we will start holidays = more more time for developing 8-)
    The CNC is printed from : https://www.thingiverse.com/thing:1719334
    I'm decided little bit change some things, for better stability and use not nema17 but nema23 for Y axis. The machine is very heavy and it's problem, to run up with small torque of nema17.
    See ya in the next topic! Roman
  • Moving in project
    loszelos05/28/2019 at 17:24 0 comments
    Hey all !! I would like to exuse me, because I didn't write a log from build too long.
    I was in hospital on surgery, my healt wasn't so good to make everything new. I had broken my 3D printer and just now I think, that I repaired finally it and I'm able to make a new parts.  I have almost done my new CNC machine for milling PCB, because I want to make a great proffesional look of them.
    I have also almost more than 50% of code done and just now is situation, that I have to done PCBs due to programing with HW which is necessary for continue in programming.
    When I will have done PCB milling machine and I will be sure that printer is correct, I will make the first prototype of PCBs and if everything will be allright I will upload files, schematics, gerber.
    Soo, thanks for patience..
  • !THE FIRST TASTE OF THE PROJECT!
    loszelos04/21/2019 at 12:52 0 comments
    Hey !! I'm soooooo glad and excited, that I can upload first pictures of boards! I'm still working on them, and lot of job is done. Just now, it's under finishing and correcting and testing. When I will be done, I will upload first files for download. Sooo please be patient.
  • !!!THE HACKADAY DEVELOPER TOURNAMENT HAS STARTED!!!
    loszelos04/21/2019 at 12:39 0 comments
View all 5 project logs
