The backbone of the entire system will be the ability to connect the various node, in the need of identify the best way to do so, i have selected five alternatives: > KNX > CAN > DALI > WIFI/RF > Developing a proprietary protocol based on DALI and CAN
(+) Pro (-) Cons
KNX (TP) - requires complex power supply - little choice of transceiver ICs (more expensive) + only 2 wires for bus and power supply + multimaster + line/bus, tree and star topology are allowed
CAN - requires 4 wires, two for power and two for the bus - only line/bus topology - requires termination resistance + multimaster + cheaper transceivers
DALI - Manchester encoding - master/slave (dali 1) + only 2 wires for bus and power supply + simple power supply + the interface is realizable with passive components + line/bus and star topology are allowed
WIFI/RF - requires power supply (mains) - not good if is inserted inside the wall + simple to implement + tree, star and mesh topology are allowed
Developing a proprietary protocol based on DALI and CAN (HW interface based on DALI protocol based on CAN) - everything needs to be developed (HW & SW) + only 2 wires for bus and power supply (DALI) + simple power supply (DALI) + the interface is realizable with passive components (DALI) + line/bus and star topology are allowed (DALI) + mltimaster (CAN)
The first subsystem I'm working on is the light control.
It is possible to have two cases: 1) more than one control per light point 2) a single control for light point
To ensure that it is possible to drive the light from any switch the node must behave as a 4 way switch.
The first case is the simplest, it is sufficient to connect the node in series to the switches [1].
The second case is slightly more tricky, it is necessary to replace the single switch with a 2-way switch and put it in series with the node [2a], or with a push-button connected directly to the node [2b].
The "SWITCH NODE" must have three functions: - switch ON/OFF the load - sense if the load is ON or OFF - communicate to receive commands and send the status of the load
