Lets just jot down some basic goals that I would like to accomplish
- Able to recharge laptop from dead at least 2 times
- Use only one USB C port on the laptop
- The one connecting USB C cable will be able to transfer power and data through the one port
- The case is able to charge at the full 100W capable of USB PD
- The case can deliver up to 100W of power to the device
- one downward facing USB C ports able to charge case and read data (thunderbolt capable)
- Two downward facing USB A ports
- Full sized SD card reader
- HDMI output
I will be breaking down working on this into two major subsections. First, the battery component and being able to charge it via USB C and then charge a laptop from the battery. And second, figuring out the USB docking station able to convert to USB A, SD card reader, and HDMI out.
