![](https://cdn.hackaday.io/images/3652241556653856140.png)
Just a quick test to see how it would fit on a PCB and if it would be difficult to route. This is the CPU only. It is connected to the mainboard by the two 2 x 18 headers. Bypass caps are not yet placed.
Routing was easy, the autorouter did it within a minute ! That is, after experimenting with placement a few hours. The size is about 100 x 150 mm.
