For generating the memory address, the square inch processor had only a H-L register pair, that had to be reloaded each time when another address was needed. For the new processor, I want to have several addresses on standby, ready to be connected to the address bus when needed. I also want 20 bit addresses.
The 74HC670 seems to be very suitable for this. It has 4 latches of 4 bits each (and only 16 pins). If we use five of them, we have four 20-bit registers. 1-to-4 decoders for read and write are built-in ! Here are the internals:
![](https://cdn.hackaday.io/images/3528171554905366422.png)
Bits 1 to 4 will get or-gates or an adder to add the 4-bit word-displacement to the address. The lowest address bit, bit 0, is used to select upper or lower byte in a word.
So, the address generation takes only 6 chips !
