The Kobold is advertised to handle 16 bit instructions, but everything is 8 bit. Even the microcode is only 8 bit wide. How does it work ?
[ What you need to know for the examples: The program counter is in register R7 (as on the PDP11), and is copied into address register PC when needed. The lowest bit of the PC is always 0.]
EXAMPLE: 16-bit ADD
As example, take an instruction that adds (X+6) to register R4:
add (X+6),R4
The instruction is split into two parts, that operate almost independent of each other:
The first byte of the instruction is fetched from (PC) into the micro-program counter. From here, the micro-instructions determine the operation:
- First part:
- load the LSB of the 16bit accumulator with (X+6), (the LSB part)
- load the MSB of the 16bit accumulator with (X+6), (the MSB part)
- fetch an instruction byte from (PC+1) into the micro-program counter (changing flow of the microcode).
This instruction byte tells to add R4 (16 bits) to the accumulator and store the result back to R4:
- Second part:
- add the LSB of (WP+4) to the LSB of the accumulator
- add the MSB of (WP+4) to the MSB of the accumulator
- store the LSB of the accumulator back into (WP+4) (the LSB part of R4)
- store the MSB of the accumulator back into (WP+4) (the MSB part of R4)
The next section of the microcode will increment the PC and start the next instruction:
- connect the LSB of the PC (from the address registers) to the B-input of the adder of the ALU. The value 2 will be provided to the A-input of the ALU, so the byte value P+2 will be put in the accumulator.
- fetch the MSB of the pc from R7 [in the workspace] and put it into the accumulator, to make 16 bits complete.
- move the 16-bit accumulator contents to the pc in the address register set.
- fetch the next instruction from (PC) into the micro-program counter.
( from here, the micro-instructions for the next instruction are executed )
EXAMPLE: 8 bit immediate load
There are also instructions that have a single opcode byte, followed by an 8-bit immediate operand or z-page location. Branch instructions are an example of this.
As example, load register R3 with value 0x80:
mov #0x80,R3
- load the LSB of the accumulator from (PC+1)
- load the MSB of the accumulator with zero
- store the LSB of the accumulator in (WP+3) (the LSB part of R3)
- store the MSB of the accumulator in (WP+3) (the MSB part of R3)
Finally, the pc is incremented and the next instruction is fetched, as in the previous example.
It's funny how we were used to CISC 40 years ago and now I cringe at the evocation of this idea :-D
I'm sorry Yann, the minimum parts requirement drove Kobold in the arms of CISC....
I notice that the CISC way can require more gates than RISC because you need some scheduling here, buffers there, some fix for a corner case...
That's why I prefer to focus on the core datapath (speed/efficiency/simplicity), then I build decoders out/around :-)
