1B Boards are in!
A project log for OPEN Power
I didn't have enough to buy a Lab Bench PSU... So I made one.
john-loefflerJohn Loeffler • 09/15/2019 at 20:03•0 Comments
Received Prototype 1B Boards back from the fab.  1B is to test the range of the Potentiometer and the spacing of the leds.  1b Is not meant to be sold.  It is a test for 1C with will integrate constant current and therefor the voltage may not be the same as the set voltage.  Use Manufacture PCBway and was a little disappointed by the quality of the Silkscreen
