Hello everyone!
One month later I debunk my suggestion from a previous log, that electromagnetic field can be charged insanely fast using capacitors as a medium. Partly it taken so long because I played with a new desktop milling machine, partly because I was trying to combine my previous schematics with not working one
This is how it ended:
After 70 conducted experiments, using indirect clues, I finally found that something was off!
Checked, re-checked and here I am : )
What does it mean for project - is that it thrown back a few steps. Important ones - it's not so convenient now and with boosted charging process it could've been a completed one. It doesn't mean that we left without options, however: using high voltage is a really questionable stuff to do, as alternative we can slow down discharging process - and it is a good way to go. It doesn't really matter, what we use - fast charge or slow discharge. Capacity helps with that - well known fact. And it's probable to find some additional methods if we are lucky, who knows!
