After a fair bit of troubleshooting, I now have a major part of this project complete:
The ESP32 can now be programmed remotely from a web interface
I'm still working on the UI, but for now it's okay:
At the top is a code editor, with full syntax highlighting. Shown is a simple example of a capacitive touch sensor program for the ESP32
Once code has been written, the Upload button triggers the compilation of code to include a lightweight web server, connects to the ESP32 via WebREPL and transfers all the required files.
To test the code, the page also has a testing area where the user can pass in any values that the function requires, and get an output from the ESP32:
There are a few UI changes that need making to tidy things up a bit, and at the moment it struggles a bit knowing they type of any values a user gives in the test area, but I'm very happy with the progress that's being made
Louis Irwin
