2x3 IDC 2.54mm, 2x3 Pogo pin 2.54mm:
- 1x - PCB (Thickness 1.6mm)
- 1x - 6pin (2x3) straight IDC Male Socket spacing: 2.54mm / 0.1 inch / 100 mil
- 6x - Spring loaded Pogo pins (Depends on the variant - P75-E2 or P75-B1)
- 1x - 10mm long heatshrink tube
2x5 IDC 2.54mm, 2x3 Pogo pin 2.54mm:
- 1x - 10pin (2x5) straight IDC Male Socket spacing: 2.54mm / 0.1 inch / 100 mil
2x3 IDC 2.54mm, 2x3 Pogo pin 1.27mm:
- 1x - PCB (Thickness 0.6-0.8mm)
- 6x - Spring loaded Pogo pins (Depends on the variant - P50-E2 or P50-B1)
2x5 IDC 2.54mm, 2x3 Pogo pin 1.27mm:
Pnoxi
DL101
Marcin Saj
