Now onto features that may or may not be implemented:
- Serial communication to set the time in a batch configuration
- GPS time
- Or radio controlled time
- Or NTP (time.google.com or otherwise)
- LED panel (video wall panel, monochrome) support
- Or I2C LCD display
- Or SPI LCD display (128x64 GLCD/OLED)
- Or simple LED matrix display
- Adjustable volume
- Automatic volume?
- Digital configurable volume perhaps?
- Adjustable brightness
- Especially automatic dimming
- Multiple languages
- If voice segments exceed 255 it won't work
- oh
- No worries, you add more folders per language
- ESP32 for NTP support
- Or ESP8266?
- Or MEGA2560???
- WIRED NETWORKS?????
- Proximity sensor for voice activation
- Wave your hand in front of the clock to make it say the time
- Integrity check
- Not everything, just basic things like SD card read failure, invalid time, low battery and speaker check
- SD card read failure and speaker check could be done by just reading the report from the module and attempting to play 000.mp3 which is a start-up sound
- Maybe have a secondary beeper inside to show that the initialization failed for voice prompt
- Have voice prompt for recoverable failures like invalid time
- Seasonal greetings
- Voice mapping documentation for custom voices
- Must include support for BUSY pin
- The voice must not rely on the static time, but on the status change from PLAYING to IDLE
- IR remote
- Temperature readout in both Celsius and Fahrenheit
- Time-dependent greeting ("Good morning", "Good afternoon", and "Good evening")
- Randomized starting line ("The time is", "It's", "It is")
- Date and year readout ("Today is Saturday, January fifth, 2019.")
- Verbose time ("It's a quarter to nine")
Torbjörn Lindholm
