Project Superseded by new platform, in design.
08/06/2022 at 05:41 • 2 commentsThis is coming soon.
Projected that there will be stackable boards 32 Thermocouple channels for each board, theoretically up to 256 channels.
Cleaned up software version
06/29/2022 at 10:53 • 0 commentsI have uploaded a newer version which cleaned up some rogue tab indentations. This has been tested under Pi OS version Bullseye.
Error with Ubuntu, Python3 and the Ncurses library.
02/18/2021 at 10:18 • 0 commentsWarning: A problem has been identified with Ubuntu running this application on the Raspberry Pi. A mapping issue occurs between the ncurses library and Python3. This is being investigated with the developers.
0.4 Version Release.
03/29/2020 at 08:29 • 0 commentsA reported bug that prevented the software starling sometimes and getting caught in the Starting 1 loop has been coded around. Anybody who still sees this bug can you report it please.
Test of PCB version 1.3
12/09/2019 at 04:00 • 0 commentsI have tested the V1.3 PCB and it works. My previous observation regarding the +/- symbols was in error and they are in fact the right way around. My next task is to design a enclosure to 3D print. At the moment I have the board inside the cardboard box that my Pi came in. To optimise performance you should minimise temperature gradients on the board. The best way to do this is to enclose it, even in a cardboard box!
Bug fix for windows smaller than printed area.
11/19/2019 at 09:31 • 0 commentsA minor bug was fixed that caused the application to close if the hosting terminal window was smaller than the displayed text. This has been resolved by specifying a minimum display window. Although this prevents the application from closing you may need to manually resize the window after the application starts to see all printed text.
Minor Update to Python code
11/11/2019 at 10:32 • 0 commentsA small start up bug fixed and new minor version uploaded.
Update PCB to Version 1.3 (part 2)
08/30/2019 at 07:23 • 0 commentsThe Ver.1.3 PCBs arrived today. I sent the Gerber files on Monday night and the PCBs were on my doorstep Friday afternoon. The price was AU$2.00 for the boards and AU$27.00 for DHL delivery.
I will attempt to get one assembled and tested over the week end.
I just noticed looking at them that I have the +- symbols on the overlay around the wrong way..........Bugger!
08/23/2019 at 07:41 • 0 commentsPosted version 1.3 PCB file and compressed Gerber files. The PCB has been modified but is untested. It "Should" work but it will b e a couple of weeks before I get around to testing it. If you are not feeling brave, the version 1.2 PCB is still available. It works but has 2 unnecessary resistors that have been removed in 1.3. You can fit any value from 0 to a few hundred ohms and it will work.
Update Circuit diagram to Ver. 1.2
08/20/2019 at 07:43 • 0 commentsUpdated circuit diagram to Ver 1.2
The circuit has been revised to reflect the removal of the two series resistors. This is as a result of the observation by Hwansoo Suh questioning the function of these components. They are there to protect the input of the converter chip from excess common mode voltage. As the multiplexer will be destroyed by anything much over +3/-0.6 volts the resistor seems a bit pointless.
The PCB is yet to be updated. At this stage if you use the Ver 1.1 PCB any value between 0 Ohm to 1K will work. I will publish an updated version as time permits.
