PCB is all laid out! I got it just under 2 square inches which is nice.
I beeped out the connector on the Vaio flex cable and wired my flex adapter so match on the motherboard end, and match a 40-pin ZIF socket on the other.
All the connections are length matched to within +/- 0.1mm too for fun and signal integrity.
NFM
