As of 4/23/2019 the build is mostly complete. For the final install position I need to install a 10 foot usb cable that I have on order yet. Once I have the final cable I'll install add a zip tie around the cable for strain relief and a little hot glue to seal the hole around the cable.
The only other thing I have planned is to add some labeling for the keys.
