I choose OLIMEX-E407 as a starting point.
After cloning micropython main repo and changing some code I can test and tick as done:
- micropython itself :)
- Ethernet
- button and LED
- SPI (it was the biggest problem, because pins with SPI are connected everywhere) - without any problem I reached 10MHz (enough for IO)
This to do next is to make slave module....
