USB to UART Serial Bridge
Cheap low pin count crystal-less USB Serial Bridge
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
The PIC16F1454 is a great alternative to common USB to UART serial bridges out there.Pros:- Less than $2- No Crystal needed- Small pin-count, 14 Pin DIP / 14 Pin SOIC / 14 Pin SSOP / 16 Pin QFN- Through-hole option- Small size, QFN 4x4mm- CustomisableCons:- My firmware uses the OS's default CDC drivers (Microchips VID PID)- Not pre-programmed, need a programmer- I haven't added TX/RX status LED pins yet, but easily added- Although the firmware works well and I haven't come across any issues yet, it hasn't been rigorously tested, and may not be as reliable as known brands. Example firmware on my github. https://github.com/johnnydrazzi/USB-Stack/tree/master/USB_Stack/Examples/CDC_Examples/CDC_Serial_UART_Example.X
