Battery Monitor
This is Wifi battery monitor that can log/store battery voltage and send the data to a database.
https://tinkersprojects.com/project/battery-monitor/
This is Wifi battery monitor that can log/store battery voltage and send the data to a database. I made this to try and debug a power problem within my car. I think the alternator is not charging the battery properly or the battery is not accepting the charge. This battery monitor will help keep track of the voltages while the car is off and running.
The battery monitor works by getting the battery voltage and send it to the database. If the monitor is offline, the device will store the voltage against the time of the reading and will attempt to resend it later. The battery monitor can log up to 3 days before starting to overwrite the oldest logged data. The Logged data is a value between 0 and 1024. By using the ohms law, the data can be converted into a voltage value across a resistor. The ADC in the ESP-12E can only r
enon0891 wrote 10/25/2022 at 13:00 • point
Monitor’s specifications and features matter because they change our experience, without the right display, everything you do on your system will seem useless. monitor for programming
