Hackaday.io Hackaday.io
Sign up Log in
Miniature Remote
A Sonic remote
lakshyaLakshya
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
5 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
  • Hackaday Prize 2019
View Gallery
648
0
5
4
Team (1)
  • lakshyaLakshya
Join this project's team
completed project
hardware
remote wireless
This project is submitted for
This project was created on 04/25/2019 and last updated 5 months ago.
Description
System consist of a compact size, sound operated remote and a receiver which detects the generated unique frequency/pattern and produce an output like switching of appliances.
Smartspeaker can act as a receiver too.
Remote has reasonable range and long battery life even on a 12 mm coin cell.
Most relevant "use" case seems as a toy. Or maybe nothing..
Details
Log In/Sign up to comment
Sign up with Github
OR
The 2018 Hackaday Prize
Replacement laptop battery with cheap Lithium cells, 3D-printed case, and re-used electronics
Project Owner Contributor
3D Printed Laptop Battery
neal-d-corbettNeal D Corbett
This is small wireless and adjustable signal generator. we can change the wave types, frequency and amplitude using control panel.
Making a 20khz Signal Generator using Bluetooth
electroboyElectroBoy
Off-grid solar & battery shed for EV Charging and RV Power.
Solar Gas Station
bryan-williamsBryan Williams
PHONO-EQ-100: a compact, cased MM phono preamp designed to run on a Li-Po battery, over 180 hours per charge, charged over USB-C.
Tiny Battery Phono Preamp for MM, USB-C Charged
elehobicaElehobica
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Miniature Remote", please tell us the reason.
Send message
Remove Member
