If you think ... this board is expesive ... no ... only http://dirtypcbs.com accept multiple boards without additional charge, I try another "cheap" manufacturers RESULT > it is 90pcs boards = more than 100$
http://dirtypcbs.com/store/designer/details/bobricius/6290/rtm-zip
If you want order this board from dirtypcbs store do not forget chose 10x10cm 1.2mm board also you receive 10pcs boards !!!!
I like DirtyPCBs :-)
