FemtoBeacon ESP32 coin
A dime sized (9mm radius) ESP32 Wifi/Bluetooth 4.2 coin.
Public Chat
Starting from
has orders / reviews
Ships from
This is a dime sized (9mm radius, 18mm diameter!) WiFi/Bluetooth 4.2 coin! The onboard LDO regulator can accept up to 5.5V, and supplies 3.3V to the coin. Available pins: UART, SPI. Includes onboard RGB LED, a push button (Boot button), and headers.
Uses a Molex 2.4GHz omnidirectional antenna.
View all 3 project logs
guida.r wrote 09/20/2019 at 21:21 • point
Is there any Arduino code to test the SPI interface?
