Another release for the LM80C firmware: version 3.2 is out now! Some code cleaning and one major adding: now the SCREEN statement gets 2 additional arguments to set the sprite size & magnification. In addition, I’ve fixed a little bug in the cold/warm reset routine that lead the system to keep into the input buffer the key pressed so that the first input walways generated a “syntax error”.
Enjoy the new firmware:
