Open Thermal Camera went through a slight redesign. The hardware is now unified for both Type-C and MicroUSB version. The housing can accept either of the PCB variants.
(Right: Type-C variant, Left: back view of MicroUSB variant)
With this step the hardware part is coming to an end and we'll start with improving the application side even further.
Hi Nathan, as of now the case isn't open sourced.
Will soon be available for purchase, so don't miss out!
Regards, Martin
Can you provide schematics for hardware design?
