For easier assembly and consistent results with heat inserts, I took an evening to create a heat insert tool for use with a Ersa soldering iron.
It looks something like this
![](https://cdn.hackaday.io/images/2482271567325048184.jpg)
It's made for M2.5 inserts, which are used in housing for our project.
![](https://cdn.hackaday.io/images/2667471567325166410.jpg)
This helps with much nicer finish as tested on our prototype housing.
