Oscillator!
A project log for Let's experiment: NEC V20 + FPGA
What happens when you connect a NEC V20 to an FPGA? Let's find out!
yh-workshopYH-workshop 04/28/2019 at 15:060 Comments
As the title said. Here we are trying to write up a simple oscillator for the V20. It looks like the V20 allows a square wave with 50% duty cycle, as long as you exceed these minimum values:
(NEC V20 Datasheet)
Here is a simple Verilog code for the oscillator:
module oscillatorV20(input clk, output reg clkV20);
reg [31:0] counter = 0;
always @(posedge clk) begin
	if (counter == 8'd5) begin
		counter <= 0;
		clkV20 <= !clkV20;
	end
	else begin
		counter <= counter + 1;
	end
end
endmodule
 And using SignalTap 2, we see this as an output (this is an example 1 MHz square wave, and I'll tune to the 2 MHz after this):
The problem with the little time bar was, I have to manually key in the "Time Units" (right click on the time bar, and click "Time Units"). Enter 100ns inside:
As this is working, my next step will be wiring the thing up to the FPGA board (ASK2CB) and check whether the ALE pin are pulsing or not.
